Bushing Lube
Old Mar 13, 2006 | 07:34 PM
MrLeadFoot's Avatar
MrLeadFoot
Default Bushing Lube
I know some folks use anti-sieze, but would this also be safe on rubber?
http://www.mobil.com/USA-English/Lub...tic_Grease.asp
Old Mar 13, 2006 | 08:23 PM
turboc5's Avatar
turboc5
What type of bushings are you using it for? Rubber suspension bushings don't use lube. For urithane I would use the clear/white lube that suspension companys sell for that. Urithane lube is actually tacky and very hard to wash off.
Old Mar 13, 2006 | 08:26 PM
MrLeadFoot's Avatar
MrLeadFoot
For stock swaybar bushings
Old Mar 13, 2006 | 08:32 PM
turboc5's Avatar
turboc5
Should be alright for that. Ive also heard of wrapping your sway bar in teflon tape. I haven't done it but it sounded like it could work. Your factory bushings should have a grafite insert in the bushing that looks like black cloth to stop binding/squeeks. You might want to look into new bushings. They should be about $10 each.
Old Mar 13, 2006 | 08:37 PM
MrLeadFoot's Avatar
MrLeadFoot
These are new, so I wanted to do something so I wouldn't have to deal with it later.
So, you think that grease is ok for rubber? Just in case I decide not to use teflon tape, or I do, and find out later it doesn't last?
Old Mar 13, 2006 | 08:47 PM
JEEP/C5's Avatar
JEEP/C5
Any synthetic grease will be safe for rubber component. I used some lithium grease front and back with my new rubber bushings. I know it should be fine but over time the paint wears off and rust develops and then they start to squeak.
Old Mar 13, 2006 | 08:55 PM
MrLeadFoot's Avatar
MrLeadFoot
Thanks for another informative post. Did you see that link to the Mobil 1 stuff I posted atop this thread? That stuff is a mixture of synthetic AND lithium. So, I guess it should be double fine?
Old Mar 14, 2006 | 06:19 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There's a "teflon impregnated" grease called Super Lube. I've used it on sway bar bushings with good results. It's sold in small tubes, maybe 1.5-2 oz, and is available in many commercial hardware suply houses.
Old Mar 14, 2006 | 11:40 AM
Face's Avatar
Face
http://www.pfyc.com/store/merchant.m...ry_Code=RGSUSP
This is the best stuff. I've never had to relube any sway bar, etc.. after using it.
Old Mar 14, 2006 | 12:40 PM
leadfoot4's Avatar
leadfoot4
That's the Energy Suspension stuff. It's good but gooooey! Takes 3-4 washings to get off your hands...wear gloves!
Old Mar 14, 2006 | 01:08 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
go to NAPA and get a tube of die-electric grease
To Bushing Lube
