question bleed brakes
Old Mar 14, 2006 | 05:18 PM
sts57c5's Avatar
sts57c5
Default question bleed brakes
I have a 2000 c5 that I got new with 35,000 miles on it and I am going to change brake pads . How often do I need to bleed the brakes?
Old Mar 14, 2006 | 07:13 PM
sts57c5's Avatar
sts57c5
Old Mar 14, 2006 | 07:38 PM
Barrier's Avatar
Barrier
If the pedal is solid you don't have to bleed, however it's a good idea to change and flush every couple of years. I would change and flush the fluid now as long as you are doing brake work. The Fluid has an alcohol base and will absorb moisture from the air. Changing and flushing periodically is a good idea. Many German cars require it every 2 years according to the owners manuals.
Make sure none gets on the paint, it will destroy paint.
Barrier
Old Mar 14, 2006 | 07:46 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Once a year is cheap insurance, especially if you do any performance driving!
Old Mar 14, 2006 | 10:13 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Every other autocross.
Old Mar 14, 2006 | 11:30 PM
sts57c5's Avatar
sts57c5
ok thanks for the help thankssssssssssssssssssssssssssss. now the window has gone out on the drivers side when it rain it pours thats for sure.
To question bleed brakes
