Reverse Lockout Wiring On Mm6
Old Mar 15, 2006 | 09:49 AM
Benchpress's Avatar
Benchpress
Default Reverse Lockout Wiring On Mm6
The two wires that are attached to the female connector on the reverse lockout switch pulled out. one is green and one is red. The connector has an (A) and (B) for each wire. which wire goes in the (A) terminal. I did a search with no results. No replacement available at the dealer... any help wold be appreciated.
Old Mar 15, 2006 | 01:55 PM
Benchpress's Avatar
Benchpress
Anyone Know where to find wire diagram online?
Old Mar 15, 2006 | 04:30 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The wires should be pink and light green.
The light green wire goes to the A terminal
The pink goes to B terminal.
Old Mar 15, 2006 | 04:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Here's the schematic:
To Reverse Lockout Wiring On Mm6
