Spark Plug Replacement help...
Old Mar 15, 2006 | 11:26 PM
Z06-Goose's Avatar
Z06-Goose
Default Spark Plug Replacement help...
I know this horse has probably been beaten to death few times over, so one more time won't hurt any
I want to replace my plugs on my 02 Z06. I have a 24-piece ratchet/socket set.
Can somebody provide the metrics of the tools needed to do this? Anything I need to disconnect or move out of the way? Tips, tricks?
I've also heard the plug wires are a bit tricky to pull off from the plugs. Any help on this as well?
Thanks in advance...
-Goose
Old Mar 16, 2006 | 12:45 AM
Speed Trap's Avatar
Speed Trap
There are instructions on changing plugs in the forum "tech tips". Here is the link: Plug change instructions
Supposedly if you twist the plug boot a little then pull it will come loose. Didn't work for me so I used a pair of pliers to grip the metal sleeve around the plug wires, wiggled it a little while pulling. The plug boot came off the plug along with the sleeve.
There were also a few posts in the last week or two about changing plugs. Sorry, I don't have the links to them, but a search might turn them up.
