What does LS1 stand for?
Old Mar 16, 2006 | 03:29 PM
Yoggi's Avatar
Yoggi
Default What does LS1 stand for?
Ok, I admit Im a dummy. But have been wondering what does the LS1 for our engine mean? Does the LS have words that go with it?
Old Mar 16, 2006 | 03:55 PM
ZO6vettepilot's Avatar
ZO6vettepilot
Little Shevy
Just kidding of course. The LS is the series designator that GM used for the engine family. LS1 / LS6 etc. I don't know if there is any rhyme or reason to the letters.
Old Mar 16, 2006 | 04:15 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Lets Screw 1 Ford at a time...
VR
Old Mar 16, 2006 | 04:28 PM
JD's C5's Avatar
JD's C5
I honestly thought the LS stood for Long Stroke because it was designed with a crank case to accomodate a Long Stroke crank shaft. However, I guess it could be just the generation III engine designation.
Old Mar 16, 2006 | 05:01 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Likety Split, version 1
Old Mar 16, 2006 | 06:36 PM
ALLEGRO's Avatar
ALLEGRO
GM has been using these codes for it's engine packages for years.
LT-1 back in the 70's along with L82 in the 80's...and many others.
Then many years later we got the LT1, LT4, LS1, LS6, LS2 LS7 and so forth. It basicly represents the generation and performance of the given engine group.
If you want more info, check this link:
http://en.wikipedia.org/wiki/Chevrol...l-Block_engine
Old Mar 16, 2006 | 07:45 PM
VETTING's Avatar
VETTING
On most other cars I have been told that it stands for Luxury Sport.
Old Mar 16, 2006 | 07:49 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
FUN
Old Mar 18, 2006 | 03:08 PM
Yoggi's Avatar
Yoggi
Thanks for the replies guys!
Old Mar 18, 2006 | 03:24 PM
David426's Avatar
David426
Luxury Touring = LT
Luxury Sport = LS
Old Mar 18, 2006 | 04:10 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Low Slung.....it's the way the vette sits. Other than that, your guess is as good as mine.
Old Mar 18, 2006 | 06:35 PM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
Low Speedy 1
Old Mar 19, 2006 | 08:35 PM
RED99's Avatar
RED99
There was LS Big blocks back in the 60's. So who knows what it stands for. Probably the CEO's initials or something totally unrelated to the motor.
Old Mar 19, 2006 | 09:04 PM
binkysgarage's Avatar
binkysgarage
It stands for, needs better heads, bigger cam and long tube headers.
Old Mar 19, 2006 | 11:26 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Just a guess but, Les Steckel. The Minnesota Vikings in the 80's
Old Mar 20, 2006 | 01:37 PM
2kbluestreak's Avatar
2kbluestreak
LS comes after LT alphabetically right? ... oops, maybe in the Russian Cyrilac alphabet.
Old Mar 20, 2006 | 09:24 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
To What does LS1 stand for?
Old Mar 21, 2006 | 11:00 AM
Gordy M's Avatar
Gordy M
L is the GM code for engine options, I believe it start with the 63 Stingrays, my 64 was a L84. The S and T versions first started with the 69 Camaro's In the top of the line small and big block engines. GM likes to recycle the engine lettering for upgraded products. The LT1 from 69-72 was used again in 92 and the LS engines from 69-74 were repopped for the 98-current designs.
Old Mar 21, 2006 | 12:59 PM
SpinMonster's Avatar
SpinMonster
J'aime le sein. Tu parle francais?
Old Mar 21, 2006 | 02:08 PM
ZO6vettepilot
I don't think anybody had the center in mind, but then again ya never know. Chevrolet is French I believe.
