MAP Readings
Old Mar 16, 2006 | 06:46 PM
SCannon's Avatar
SCannon
Default MAP Readings
What should be an average reading out of my MAP be at idle "1k"
On a gauge I have its showing 0.5
Old Mar 16, 2006 | 09:15 PM
SCannon's Avatar
SCannon
anyone?
Old Mar 16, 2006 | 09:49 PM
ArKay99's Avatar
ArKay99
Are you stock? 1K idle doesn't sound stock... I use EFILive and with my setup (check sig) I idle around 55kPa @850rpm's. I know somebody with the same cam on a 114 and he idles around 47kPa. If I remember correctly when I was stock I idled around 30kPa @ 700rpm.
Old Mar 16, 2006 | 10:21 PM
SCannon's Avatar
SCannon
The most it hits when revving is 30's I think. I have 538 RWHP thats why the 1k idle. Kpa?
Old Mar 16, 2006 | 11:08 PM
ArKay99's Avatar
ArKay99
Manifold pressure in kilo Pascals, it's metric. 105 kPa is sea level air pressure so 55kpa I'd guess is around 7.5psi or .5 bar.
Old Mar 17, 2006 | 07:43 AM
SCannon's Avatar
SCannon
Ahh so my gauge might be reading in Bar...
Old Mar 17, 2006 | 10:26 AM
ArKay99's Avatar
ArKay99
That what I was thinking.
Old Mar 17, 2006 | 04:41 PM
TSDuke's Avatar
TSDuke
Mods in sig, mine idles at 900, at 59-60 kPa.
To MAP Readings
