After a few months of research and soul-searching, I've decided to get the NX Express Nitrous Kit, GenX2, remote bottle opener, rocker panel assembly, MSD window switch (3K and 6K pills), and BP WOT switch.
Does anyone have a web page or some instructions on how to install all of this on a C5? Any and all advice is appreciated!
NX makes a great C5 kit Have installed NX nitrous kit with all the goodies on my 2000 and 2001 Z06. If you have ??? on install e-mail me can walk you through install. Install is simple but time consuming.
The instructions that come with the kit suck. I would get it installed but I'm lazy. I think the best advice I can give you if you want to do it your self, try to get someone to help you that has done one before if you can. Good luck.
Go to Ls1.com and look under the Nitrous section. I have pics of my TNT wet install but have not put them up yet. Very very easy. The only somewhat hard thing was wiring the MSD tach line to the pcm. I kept dripping solder on myself and did one hell of a horrible soldering job, but it sure is stuck there. :yesnod:
AlsoI took off my FPSS b/c it would get in the way of my valve covers ( mine FPSS stuck straight to the sky for some reason when fully tightened). Oh well justwire the two wires together.
