Clutch time, any suggestions?
Old Mar 17, 2006 | 12:24 PM
ROJO99's Avatar
ROJO99
Default Clutch time, any suggestions?
Thinking of having a Spec Stage3 installed but really do not have any idea on the best application.
My set is as follows, 99FRC, Vararam, LS6 intake, Thunder 230/224 cam and Melrose LT headers. Best run pre cam was 12.20@114 with DR's.
Thanks in advance.
Old Mar 17, 2006 | 12:34 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
cartek.net awsome clutch
Old Mar 17, 2006 | 01:04 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
LS7 clutch and flywheel with hardened output shaft and DTE Brace if you keep running quarters.
I run a RPS clutch which I love so that is anotehr option, but it is more money.
Old Mar 17, 2006 | 01:18 PM
WKMCD's Avatar
WKMCD
LS7 clutch here with 460-470 RWHP and hardened output shaft in the 3.90's. Add the Cartek adjustable master and you're good to go!
Old Mar 17, 2006 | 01:59 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
thats what im getting
Old Mar 17, 2006 | 02:20 PM
nikolai's Avatar
nikolai
Thanks in advance.
DO NOT go with the spec...many, many people reporting problems with this clutches....check out this thread
Old Mar 17, 2006 | 02:40 PM
NVR BRNG's Avatar
NVR BRNG
What kind of RW Torque are you making?
The LS7 clutch is a good option but does anybody know how much torque it can handle and for how long?
My current tune is only making 390 RWTQ, but I'm still going with the RPS clutch & flywheel. It's rated at 550-570 lb./ft. torque, so I can plan further power increases knowing the limits of the clutch.
My 'Vert will be going to Andy's for this install & 3.90 and possibly a G5X3 upgrade from my Comp Cam 224/224 .581" 114 LSA.
Old Mar 17, 2006 | 03:05 PM
Sportsdude's Avatar
Sportsdude
I'm planning to go with the LS7 when my LS6 goes.
Old Mar 17, 2006 | 07:06 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I also went with the RPS setup and like the setup so far and I am running some sick hp with it
To Clutch time, any suggestions?
