question about hurst shifter
Old Mar 17, 2006 | 06:00 PM
97 c-5's Avatar
97 c-5
Default question about hurst shifter
a friend of mine has a hurst shifter out of a 00 camaro ss and was wanting to know if that would fit in my 97 c5 it is alot shorter throw.
Old Mar 17, 2006 | 09:25 PM
CCrane65's Avatar
CCrane65
The F-body shifter is a two piece unit with a removable stick. It has different threads on the stick so none of the Corvette ***** will work on it.
As far as whether the shift mechanism and baseplate will match up with the Corvette transmission, I would imagine not otherwise Hurst would not have bothered to go to the expense of tooling up a new shifter when they could simply market the existing shifter at a considerable profit vs cost advantage.
cc
Old Mar 17, 2006 | 09:35 PM
TEXHAWK0's Avatar
TEXHAWK0
Nope, don't think so.
I had a 96 SS with Hurst shifter and the design was totally different.
The Camaro shifter actually fit into the top of the transmission housing and sealed to the case. The C5 shifter is mounted in its own housing in the tunnel with shift linkage that goes back to the transmission.
Old Mar 17, 2006 | 11:15 PM
Lemansblueboy's Avatar
Lemansblueboy
Have a Hurst from my 04 that will fit your 97, Used one season, wife said to stiff haroldgigi@comcast.net
To question about hurst shifter
