P0133 & P0153 codes after header install
Old Mar 17, 2006 | 11:26 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Default P0133 & P0153 codes after header install
After installing my LG stainless steel street headers, I keep throwing these codes for the 02 sensor heaters and of course it is turning on the check engine light. Does anyone else have this problem when installing headers? How do I get the light to stay off? I talked with LG and they mentioned something about newer vettes having hotter heaters in the 02 sensors after 01, but my car is an 02, so I am not sure how to tackle this issue.
Thanks,
--Chris
Old Mar 18, 2006 | 12:35 AM
Shane_S's Avatar
Shane_S
I got a P0140 a few days ago. roughly the same thing. I just had them turn the code off. Its probably a problem with your o2 sims if thats what you got.
Shane
Old Mar 18, 2006 | 09:27 AM
dpd's Avatar
dpd
Thanks,
--Chris
2 choices.get a set of new front o2's or use the adapters and move your rears up front.i have the older lg pro system[only uses 2 sensors,no rears]and moved my rear 02's up to the front.no problems in 2 years. your faults are for slow response.i don't know how many miles are on your o2's,but if you get new fronts your problem will most likely go away.
Old Mar 18, 2006 | 10:59 AM
St. Jude Donor '09
My system is using just two O2 sensors, the rears were turned off during the dyno tune, the rears have been put in as the front sensors as they apparently have less tendency towards this problem. My sensors have 30k on them right now.
thanks
--chris
Old Mar 18, 2006 | 06:54 PM
St. Jude Donor '09
I pulled the O2 sensors out this afternoon and cleaned them with carb cleaner and blew them out with compressed air, this is what LG suggested, and I still got both codes thrown on the drive home, does anyone have any suggestions for this before I drop a couple hundred bucks on O2 sensors that still might not fix the problem?
Thanks,
--Chris
Old Mar 18, 2006 | 07:05 PM
dpd's Avatar
dpd
get o2's.the carb cleaner really killed them[that was a no-no]
Old Mar 18, 2006 | 11:36 PM
St. Jude Donor '09
Ok...I dont understand why LG would tell me to clean the sensors with carb cleaner and blow them out if it would destroy the sensor. Im starting to remember why I quit modifying cars. The power and noise is fun, all the little codes and other annoyances detract from that fun.
Anyone with experience with this is appreciated,
--Chris
Old Mar 19, 2006 | 01:44 PM
shulamite's Avatar
shulamite
Default 1153 code
Have almost the same problem since installing Dynatech Supermax headers, cats, and x-pipe. Code 1153, insufficient switching, right side,rear. I bouight 02 simulators and install them .cleared code and the second cycle, got 1153. Car runs like a scalled dog, no complaints there. Hate seeing ch eng light. Will probably LS1 Edit out the 02 sensors. Unless somebody has the answer. I would rather do it right.
Old Mar 19, 2006 | 01:58 PM
dpd's Avatar
dpd
--Chris
i don't get that one either.carb cleaner is a hydrocarbon just like gasoline.raw fuel will kill a o2 sensor.plus slow switching is because of the heaters.if the o2 fuse under the hood is not b lown,the heaters in the o2's are worn out.it is common for the heaters to tank over time.when you add headers the faster exhaust flow doesn't allow enough heat on the sensor[the stock system retained enough heat at the sensors to compensate for the worn heaters]
Old Mar 19, 2006 | 02:01 PM
dpd's Avatar
dpd
your fault is for the FRONT sensor on bank 2[right]not th rear.you need a front o2.that's why simms didn't help your problem.same thing as chris' problem.the heater is worn out.
Old Mar 19, 2006 | 02:55 PM
St. Jude Donor '09
Thank you very much dpd, I appreciate your input and advice very much, I am going to order two new O2 sensors. From looking at my car, it appears they use the factory rear O2 sensors as the "front" O2 sensors for the headers, should I order sensors for a 2002 model year, or did they upgrade the sensors for 03 or 04?
Thanks again,
--Chris
Old Mar 19, 2006 | 03:08 PM
dpd's Avatar
dpd
Thanks again,
--Chris
order 2 rear o2's for a 02/03,04 is a completely different plug.rear o2 heaters have a higher wattage heater
Old Mar 19, 2006 | 07:00 PM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
I'm having the same issues after headers. I'm told the 1153 codes and others can be "edited" out to eliminate the "Check Eng" light. Any rich/lean issues caused by this? I check engine lamps by the way. Now I'm wondering if I modded too far. Today the car started "surging" while under cruise control? WTF?
Old Mar 19, 2006 | 07:18 PM
dpd's Avatar
dpd
lazy 02 sensors create mixture problems.turning off rears isn't a issue[all they do is monitor cat efficency],turning off fronts is a issue.
To P0133 & P0153 codes after header install
