Jacking points
Old Mar 18, 2006 | 01:12 PM
keyser's Avatar
keyser
Default Jacking points
lets imagin your car was sitting on 4 concrete blocks that were positioned under the jacking points on the rockers.....( bad story).
where would be the other places to jack the car up with out damaging it anymore?thanks
Old Mar 18, 2006 | 01:14 PM
yaonttwo's Avatar
yaonttwo
Under the front or rear crossmembers.
Old Mar 18, 2006 | 04:27 PM
rws.1's Avatar
rws.1
follow this thread...
I use the wooden jacking pads on the cross members
http://forums.corvetteforum.com/show...s&forum_id=103
Old Mar 18, 2006 | 07:25 PM
lloyd's Avatar
lloyd
Default crossmembers
Old Mar 19, 2006 | 11:09 AM
turboc5's Avatar
turboc5
If you jack it up under the jacking points without pucks be careful. If it hangs over onto the white floor board thats only fiberglass and balsa wood. It crackes very easly. The painted portion of the rocker obvisly also cracks very easly. Jacking from the subframes are your safest bet. Rear crossmember that the sway bar bolts to and the front one just under the steering rack are the strongest ones. You might have to drive it up on blocks to get it under the front one though.
Old Mar 19, 2006 | 11:13 AM
turboc5's Avatar
turboc5
Oh and please DON'T use concrete blocks. They can be brittle with uneven pressure points, brake and crush you. Get some chepo jack stands. You can probly get some for $20
Old Mar 20, 2006 | 01:14 PM
keyser's Avatar
keyser
I didnt put the car on blocks. the bastards that stole my wheels did. Thanks
Old Mar 20, 2006 | 01:17 PM
rws.1's Avatar
rws.1
Old Mar 20, 2006 | 06:14 PM
lloyd's Avatar
lloyd
Old Mar 20, 2006 | 07:02 PM
Shane_S's Avatar
Shane_S
And they put the blocks under the jack points? I'm actually impressed by that a little.
Shane
Old Mar 20, 2006 | 10:48 PM
turboc5's Avatar
turboc5
Shane
Thats true, It would of been so easy for them to put them under the floor boards ripping a hole threw them. Sorry to hear about your wheels , I hope it all works out
Old Mar 21, 2006 | 10:27 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
WTF is wrong with people. Sorry to hear aout this. Crossmembers for sure the best place to lift car. Hope you can find out who did it, get them arrested, then after incarceration(8 months after release) kick the shi8 out of them. Revenge is a dish best served cold.
To Jacking points
