RR Rattle
Old Mar 19, 2006 | 09:39 AM
00 NBFRC's Avatar
00 NBFRC
Default RR Rattle
Noticed this after installing the TI exhaust. Everything seems to be snug and tight, however when I go over a little bump or change in pavement you can hear it. I took that metal clip off the diff housing and replaced it with tie wraps for the harness, but that didnt help any.
Old Mar 19, 2006 | 11:03 AM
azmusclecar's Avatar
azmusclecar
Maybe your exhaust pipe over the axle is too close to the fuel tank shields. If you can maybe run your hand up the pipe and maybe press the shield up and away from the pipe. Just a suggestion. Maybe others can help............
Old Mar 21, 2006 | 01:01 AM
00 NBFRC's Avatar
00 NBFRC
Got it fixed. The RR sway bar bolt wasnt tight enough. Thanks for the feedback!
To RR Rattle
