when to change vortex filter?
Old Aug 15, 2001 | 01:13 AM
Topless Mag's Avatar
Topless Mag
Default when to change vortex filter?
it's been 7 months and 5k miles when do i change it ,where do i get it ,and how easy is it to install ?...mucho gracias .
Old Aug 15, 2001 | 09:16 AM
ncvetteman's Avatar
ncvetteman
Default Re: when to change vortex filter? (Topless Mag)
You already have the Vortex and want to replace the filter in it...correct?. If so, check to see if it is visually dirty, it may not need changing. You can replace it with another filter...avaible from any vendor that sells the Vortex...and in the forum mall. It is also cleanable, us a K&N recharge kit aviable at most auto parts stores.
Old Aug 15, 2001 | 09:58 AM
Austrian Vette's Avatar
Austrian Vette
Yep, clean it wit a K&N cleaning set.
Michael
Old Aug 15, 2001 | 10:24 AM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: when to change vortex filter? (Austrian Vette)
I just checked mine recently, it had been 10K miles since I had last cleaned it.....air filter looked brand new, not a hint of dirt on it. I figure that you can probably go 20K+ miles between cleanings but if it is really dusty where you live of course you will need to clean it more frequently.
I used the K&N cleaning kit for mine.
Old Aug 15, 2001 | 10:34 AM
C5go's Avatar
C5go
Cruise-In III Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I've been advised every 5 -10k miles depending on conditions. Yes, it is cleanable. I've got a spare that I keep clean and sealed in a ziploc. That way I just swap them out and then clean the dirty one, reoil and then seal it up in the ziploc for the next time. The system works great for me!
Old Aug 15, 2001 | 10:55 AM
ncvetteman's Avatar
ncvetteman
In addition, spare are usually $45-50. The cleaning kit is usually $15-18.
Old Aug 15, 2001 | 06:48 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
NCM Ambassador
As ours is an EDD, I clean it every 5,000 miles. Works good every time.
You would be suprised what I find up in the front of the evaporator core & in the air cleaner............ Styrafoam blocks, leafs,etc.
Water temps do not go up either! (except during runs in the mountains during the fall.....lots-o-leaves).
You can CARFULLY blow out the filter with compressed air, then soak & reoil after drying.
Steve
Old Aug 15, 2001 | 11:23 PM
Don&Kelly's Avatar
Don&Kelly
I clean mine every 5K miles , it never looks like it needs it - but if it's dusty where you live you need to clean it more often.
:seeya
Old Aug 16, 2001 | 05:09 AM
ledfoot's Avatar
ledfoot
Default Re: when to change vortex filter? (Don&Kelly)
I don't have the Vortex but I clean my donaldson/Halltech filter every 5k. The K&N cleaning kit is perfect for the job.
David In Indy :seeya
2000 NBM M6-Coupe
All Options minus F45
Euros/Lloyd Mats/Chrome Shifter/Ripper/Halltech tric/T-bypass/Taylor
Wires/TTS Headers/High Flow Cats/X-pipe/Indy Corsas/Baers/Z06
Calipers/Russell ss brake lines/Hawk Pads/Porsche DOT4 Hi-Performance Brake
fluid/Redline oils/Zaino/Engine Dress by Auto Buffs and Design Specialties
Old Aug 16, 2001 | 11:00 AM
BAD2BNE's Avatar
BAD2BNE
The Vortex filter will not get very dirty in normal use over a period of 10K miles or so..but the oil will dry quite a bit and the filtering effect will decrease.
So, even if your filter does not seem dirty, check the oil coating regularly. If it seems to need it, re-oil it between cleanings. You will get the best filtration from your filter that way. Just don't over oil either, just a light coat as you do when first re-oiling after the cleaning process.
Hope this helps and good luck :cheers:
Old Aug 16, 2001 | 01:34 PM
4THTOY's Avatar
4THTOY
I clean mine at every oil change, I drive along the beach every day, I dump enough sand out of it to make my own sand box. It's easy to do when the car is on a lift anyways.
Ira
Old Aug 18, 2001 | 11:32 PM
austinvetteman's Avatar
austinvetteman
If the Vortex is anything like the K&N filter (I believe it is similar) then the following should apply.
K&N actually recommends letting the dirt build up on the filter. Supposedly it will perform better as more dirt builds up. The only thing you have to worry about is making sure the filter has sufficient oil to help capture new dirt. Don't let it dry out. Cleaning periods should be few and far between depending on the conditions in your area.
This contradicts what others are posting but I've installed K&Ns on other cars and know this to be true.
Austinvetteman
To when to change vortex filter?
