Turn signal disaster please help!!!
Old Mar 20, 2006 | 03:04 PM
wore's Avatar
wore
Default Turn signal disaster please help!!!
The passenger side signal went out and I replaced the bulb and it did not fix the problem. I thought maybe I got the wrong bulb and took the driverside out to use as a check. Now they both do not work and I get the rapid blinking. Any info would be great.
Old Mar 20, 2006 | 03:13 PM
cliff_ford's Avatar
cliff_ford
Did you put the original bulb back in the driverside?
Old Mar 20, 2006 | 05:18 PM
wore's Avatar
wore
I replace the original bulb in the drivers side and it does not work.
Old Mar 20, 2006 | 05:20 PM
dpd's Avatar
dpd
sounds like the bulbs are in backwards
Old Mar 20, 2006 | 05:27 PM
wore's Avatar
wore
I tried switching, turning, and flipping them.
Old Mar 20, 2006 | 05:31 PM
dpd's Avatar
dpd
if the left side worked BEFORE you took it out,either the bulb is blown,the filaments shorted together or the bulb is in backwards.
Old Mar 20, 2006 | 05:58 PM
cliff_ford's Avatar
cliff_ford
Try buying two more bulbs and start again
Old Mar 20, 2006 | 06:10 PM
game on's Avatar
game on
Default Turn signal bulbs
I replaced both fronts a couple of weeks ago and had the same problem.
I pulled both new bulbs to make sure I had the correct bulbs, which I did. I noticed that the new bulbs were easy to pull out which led me to believe I didn't install them correctly, not completed seated.
That turned out to be my problem, not seated. The bulbs should be a little hard to pull out if they are properly seated.
Old Mar 20, 2006 | 06:54 PM
wore's Avatar
wore
I just went to wash my car and i was fiddling with my hazard lights and the passenger side turn signal started working. I then took out the drivers side and put a new bulb in and and wiggled it while the hazard lights were on. Now they both work. Thanks to all who helped. This place is great.
To Turn signal disaster please help!!!
