Lug nut torque?
Old Mar 21, 2006 | 07:27 PM
wmmaryyoung's Avatar
wmmaryyoung
Default Lug nut torque?
I am mounting some new tires and had them all off with the car on jacks. I had to paint some curb rash on the right side. Anyway what is the proper lug nut torque? All I know is I used my Milwaukee 18 volt impact to take them off and they were much tighter than I would have imagined. They have never been off before. Thanks for any help.
Old Mar 21, 2006 | 07:36 PM
Pumba's Avatar
Pumba
The first thing to realize is that you should never use an impact wrench on your lug nuts.
The following is the torque sequence I use for installing my wheels:
1) Finger tighten all 5 nuts
2) Following a star pattern tighten all 5 nuts to 25 lb-ft.
3) Repeat using the star pattern to 50 lb-ft.
4) Repeat using the star pattern to 75 lb-ft.
5) Finish using the star pattern to 100 lb-ft.
6) Drive for a short period and retighten to 100 lb-ft.
Old Mar 21, 2006 | 10:20 PM
rws.1's Avatar
rws.1
100 ft-lbs on dry, non-lubricated studs
Old Mar 21, 2006 | 10:27 PM
chocoholic's Avatar
chocoholic
Yes, tighten in a star pattern. Yes, recheck after a short while. Actually, checking the wheel nuts ought to be part of your normal checks along with tyre pressure and condition (I know, few do).
But, IMHO doing the tightening that precisely and over that number of increments is way past overboard. Still, that's certainly better than not doing it at all!
p.s. This stuff is also to be found in that secret thing called the owner's manual.
Old Mar 22, 2006 | 12:02 AM
MrLeadFoot's Avatar
MrLeadFoot
Why not?
Old Mar 22, 2006 | 07:24 AM
Oldvetter's Avatar
Oldvetter
Uneven torque on your lug nuts can cause rotors to warp. Warped rotors cause brake pedal pusations. Never use an impact wrench to tighten them. Always use a torque wrench.
You can use an impact wrench to loosen them.
Old Mar 22, 2006 | 07:47 AM
RC5's Avatar
RC5
Good advise from Pumba...One who knows.
Aside to Pumba,enjoyed the conversation,both clubs are looking forward to the visit.
To Lug nut torque?
