Help...radio's locked
Old Mar 21, 2006 | 08:11 PM
thnkfast's Avatar
thnkfast
Default Help...radio's locked
I have an '02 Z06 and I'm not the original owner. I had to do a battery change at Road Atlanta this weekend and now the radio's locked. It made for a long 5hr drive back to NC.
I understand that this is an anti-theft feature but I would now like my radio back. Can some one give me a hand or direct me to a past thread that covers this.
Thanks in advance....
Todd
Old Mar 21, 2006 | 08:58 PM
BadBone's Avatar
BadBone
Here's what i found by doing a google search of "C5 radio lock", I hope that it helps you.
Procedure: 01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don't take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You'll hear "Invalid Code, try again"
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (star)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC
Old Mar 21, 2006 | 09:17 PM
jerrymcb's Avatar
jerrymcb
This sounds correct. If by some chance it does not work
check in tech tips. The procedure there has been used successfully
(at least in the past). With out checking this looks like the same
procedure.
Old Mar 21, 2006 | 09:44 PM
108C6's Avatar
108C6
if u can not get the back up code out radio may be in inop mode just leave key in acc. position for 1 hour. this happens when wrong code has been tried 3 times or more. to see if it is in inop just push am/fm it will display inop.
Old Mar 22, 2006 | 09:52 AM
thnkfast's Avatar
thnkfast
Thanks guys, I'll try this as soon as I get home from work.
To Help...radio's locked
