A4 guys Torque Man. question.
Old Mar 22, 2006 | 04:08 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default A4 guys Torque Man. question.
Do your track times get any better when you turn if off.
Old Mar 22, 2006 | 05:38 PM
Bounty's Avatar
Bounty
Waiting for my cam install/tune to have the TM adjusted. A lot of guys do not recommend removing it all together but rather changing the settings upwards. You probably want some measure of safety if it's your daily driver. Those I have talked to all say the difference is felt at launch and can help those lagging 60 foot times...
Old Mar 22, 2006 | 06:09 PM
1-BAD-VETTE's Avatar
1-BAD-VETTE
On my TA, deleting torque management was what made the biggest difference in tuning when i had my car tuned for my ss4000 stall.
Old Mar 22, 2006 | 06:10 PM
booker's Avatar
booker
I don't know. It's just something I do to help with consistency.
Old Mar 22, 2006 | 06:21 PM
screw991le's Avatar
screw991le
Traction control would be my safty net. I just want to know how much power the car is getting robbed from the TM.
Old Mar 22, 2006 | 06:52 PM
Bounty's Avatar
Bounty
I didn't mean safety net as in not crashing I meant safety net as in not grenading rear output shaft, tranny, etc. You won't be launching with the Traction Control on anyway so that point is moot. Definitely have it adjusted, either raising the limits or removing it completely. Even bone stock it is holding you back.....
Old Mar 22, 2006 | 07:16 PM
screw991le's Avatar
screw991le
I am trying to figure out how far back it is holding the A4s
Old Mar 22, 2006 | 07:23 PM
Bounty's Avatar
Bounty
The problem with what you're asking is this.....no one just turns off the Torque Management. Since they would have to be in your PCM file to turn it off, it usually means you are getting a tune. That means shift points and firmness are being adjusted, air/fuel optimized, and maybe 5 to 10 horses being "uncovered." Even the handhelds will get you 5 hp and adjust shifting/remove TM. So TM alone is hard to gauge. "Hanheld programmers on an A4" thread might get you a little more of the info you're looking for.
Only experience I've had with a handheld is the Diablo Predator on my friend's car....picked up 3 tenths in the quarter mostly due to shift point adjustment, no TM, and finally being able to launch it and get a decent 60' time. Doesn't do near as much for the manual cars.
Old Mar 22, 2006 | 08:03 PM
screw991le's Avatar
screw991le
Old Mar 23, 2006 | 10:58 AM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by usd2sing
remove tm. programming will do this. not a hand held.
source ?
Old Mar 23, 2006 | 11:17 AM
screw991le's Avatar
screw991le
FYI, my car does not have AH or Comp mode.
Old Mar 23, 2006 | 12:27 PM
mnotx's Avatar
mnotx
If you will send me your e-mail address, I can send you a screen shot of exactly what TM is programmed to do for a stock 2003 A4 tune. The stock programming in mine effects only the 1-2 and 2-3 up-shift. There is no TM with the 3-4 up-shift. You may also have "Abuse Mode" which throws in a lot of TM when necessary.
mnotx@***.net
Old Mar 23, 2006 | 03:04 PM
Mike Mercury
most tuning software like ls1 edit, hp tuners, pretty sure efi live will also work.
hand helds dont go deep enough in the files, to get you there.
several parameters cam be modified, abuse modes, etc.
Source (and this time not yourself)???
my Predator completely turned off TM.
Old Mar 23, 2006 | 03:35 PM
Bounty's Avatar
Bounty
Same with the Predator I had experience with.....completely turns off TM.
Old Mar 23, 2006 | 04:22 PM
screw991le's Avatar
screw991le
Mike and Bounty any better times or notice of heat, noise etc?
Old Mar 23, 2006 | 04:31 PM
Bounty's Avatar
Bounty
As stated in one of my previous posts in this thread, we picked up 3 tenths in the quarter after reprogramming an otherwise stock A4 with the Diablo Sport Predator largely due to the changes in shift points/firmness and removal of TM. He has had NO driveability issues with this car or mod. Hope this helps....
Old Mar 23, 2006 | 04:34 PM
screw991le's Avatar
screw991le
Thanks, I have been reading this for to long and only looked at the posts from just now.
To A4 guys Torque Man. question.
Old Mar 23, 2006 | 04:45 PM
usd2sing's Avatar
usd2sing
i had no idea...so a major back pedal on my part..sorry.
when i was researching tuning options (here) i was told that the hand helds didnt have the functions to remove tm...
again sorry. i'll pull my posts for being a dunce...DOH!
Old Mar 23, 2006 | 04:55 PM
Bounty's Avatar
Bounty
But remember, just because it does turn off TM doesn't mean it's the best way to go. For the price of a Predator ($349 to $399) you are almost at the price of a good custom dyno tune. No comparison! Research some good tuners in your area and go check them out. You'll be happy you did....
Old Mar 23, 2006 | 08:18 PM
usd2sing's Avatar
usd2sing
399 for a lifetime tune. add a mod that requires a retune...its free..
