Proportining valve
Old Mar 24, 2006 | 02:16 PM
70 LS1's Avatar
70 LS1
Default Proportining valve
Did early C5's have an external proportioning valve? Where is it located? Is this where the DRM spring goes? I know that if the car has active handling rear brake proportioning is controlled electronically by the ABS module, but what if the car does not have active handling?
Old Apr 17, 2006 | 11:08 AM
JETSET's Avatar
JETSET
Default valve
It is located inside the master cylinder
There is a plug on the front of it
