Fuel pump suggestions?
Old Mar 24, 2006 | 04:10 PM
Y2KRoadster's Avatar
Y2KRoadster
Default Fuel pump suggestions?
Which kind should I get? I have a 2001 6-speed supercharged Corvette. The car ran out of fuel up top and I need something in tank that can support around 600 at the wheels. I was thinking about the holley that is shown here:
http://www.thunderracing.com/catalo...&vid=7&pcid=165
My only question is, will I need to modify anything to make it fit? Thanks!
-Brent
EDIT: I also plan on running the KB Boost-A-Pump but am not sure what setting it should be on for this kind of power...again, thanks for the help! I also currently have 42LBS injectors on the car...
Old Mar 24, 2006 | 09:46 PM
RunNE1's Avatar
RunNE1
Check the F/I forums for better info. From what I gather the normal setup is either a intank LPE or Racetronix pump augmented with a boost referenced MSD or KB boost a pump for FI cars. The LPE seems to be the more reliable pump. Both should support ~700 hp. You could also do alcohol injection or, if you want to spend more money, you could go with an ECS custom fuel system.
Old Mar 24, 2006 | 10:28 PM
Y2KRoadster
I saw the LPE Walbro 255 pump for $299...and then on another site I saw a Walbro 255 pump (for a Corvette) for $130...what is the real difference between the two?
Old Mar 24, 2006 | 10:36 PM
wavrdr's Avatar
wavrdr
I "believe" that the LPE comes with a new basket so it's a simple plug-n-play operation, while the $130 pump is only the pump and requires a retrofit to your current basket.
Old Mar 24, 2006 | 11:42 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I run the LPE intank pump with the KB BAP and I run in the mid 700 to the rear and so far so good, although I converted my system to the 97-98 model with the return and see high 50's under WOT, I also have to feed 60 lb Motrons
Old Mar 26, 2006 | 01:29 PM
Y2KRoadster
Was the fuel pump easy to install.
To Fuel pump suggestions?
