Keeping it cool
Old Mar 24, 2006 | 10:43 PM
Tom Porter's Avatar
Tom Porter
Default Keeping it cool
Does anybody suggest that I change my thermostat to a lower temperature range, say 170 degrees. Would this help keep the temp. down in heavy traffic?
Old Mar 24, 2006 | 10:50 PM
1965imp's Avatar
1965imp
PUT A 160 degree thermostat in it and have your cooling fans adjusted to the new thermostat. It should run alot cooler in traffic!
Old Mar 25, 2006 | 01:43 PM
corvettebob1's Avatar
corvettebob1
The only way to reduce the engine temp is to increase the size of the radiator.
Changing the thermostat only changes the point at which it starts to open.
Changing the fan settings will help some but will not change the stablized temps.
Old Mar 25, 2006 | 04:10 PM
warren s's Avatar
warren s
If you run a lower temp T-stat AND install a fan overide switch (either a manual switch or change to the ECM) you can keep the coolent temps down even while in traffic.
The stock radiator is up to the task on a stock engine. Though many will argue with the benifits of running cooler.
Old Mar 25, 2006 | 04:35 PM
David426's Avatar
David426
I have a 180 degree thermostat and the fans are adjusted to come on earlier. Coolant temps run between 192-205. Even in the summer. Before I did this, my coolant temp was running around 220-230. Ouch. Transmission also runs cooler too. Heat will fry these A4 trannys. I guess if I lived up North somewhere, I might leave it alone or only run a 180 during the summer. It too dang hot here in Texas
To Keeping it cool
