reverse Lock Out...Yes or No ?
Old Mar 25, 2006 | 12:46 AM
ALLEGRO's Avatar
ALLEGRO
Default reverse Lock Out...Yes or No ?
Title says it all.
I have gone too far over to the right and got a grind......thought there was a lockout?
Old Mar 25, 2006 | 01:34 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Mar 25, 2006 | 01:58 AM
Bill Dearborn's Avatar
Bill Dearborn
There is a reverse lockout solenoid. However, it is designed to be over riden by pushing on the shifter hard enough (which isn't too hard in some cases). The solenoid works in conjunction with a spring that provides the lockout force. Once you overcome the spring pressure you will go into reverse. GM designed this as a fail safe in case the thing failed in the lockout position. You could still get the car into reverse to move it.
Bill
Old Mar 25, 2006 | 08:27 AM
MadMaxZ06's Avatar
MadMaxZ06
I had the same problem. In my case, the reverse lockout selenoid was "lazy" or at least intermittent. It certainly didn't happen all the time, but sometimes when I was intending to shift to 5th, it would allow travel over into reverse. Additionally, of the few times it did occur, it was always my first attempt to shift into 5th since starting the car. The reverse lockout selenoid was replaced, PROBLEM SOLVED.
- Max
Old Mar 25, 2006 | 10:54 AM
rws.1's Avatar
rws.1
As posted above there is a rear lockout solenoid. Have it replaced before yo do some damage
To reverse Lock Out...Yes or No ?
