wiring diagram for door control box
Old Mar 25, 2006 | 10:35 AM
pablo_vet's Avatar
pablo_vet
Default wiring diagram for door control box
hi, the control box in my drivers door for my 98 c5 has packed up. apparently this can be fixed ,but the auto electrician needs a wiring diagram for the box. does anyone have or know where i can get this. it is the box that controls the window, mem seats and wing mirrors!
gm parts number 9352881 (select chevy and use part number) there is a picture
any help would be great.
Old Mar 25, 2006 | 10:51 AM
SpeedyZ's Avatar
SpeedyZ
That is something you will probably never see unless someone reverse engineers the box and draws up a schematic. GM (as well as most OEM) does not publish schematics for their electronics modules. Matter of fact they normally use custom chip numbers so you don't know what they are.
What part is not working? If it is the window motor control it is most likely bad contacts in the relays. I think they are standard parts and not numbered with custom numbers.
Old Mar 25, 2006 | 12:43 PM
pablo_vet's Avatar
pablo_vet
bugger, well if anyone for some reason does know...
To wiring diagram for door control box
