Brake Bleeding??
Old Mar 25, 2006 | 12:44 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Default Brake Bleeding??
Just put my newly painted calipers back on and now I'm having trouble. The brakes bleed great but then the pedal looses pressure and goes to the floor. Pump again and the pressure returns but stop and the pedal will go to the ground. Did I get air in the ABS system? Does it now have to go to the dealer to be hooked up to the scanner? Any help would be great. Thanks
Old Mar 25, 2006 | 10:26 PM
LoneStarFRC's Avatar
LoneStarFRC
Dupe deleted
Old Mar 25, 2006 | 10:27 PM
LoneStarFRC
If you don't have any air or leaks, you may need a new master cylinder. If the internal seals on the piston of the master cylinder are worn/damaged/torn etc, the fluid will bypass when you push on the pedal. The pressure initially feels like you have some pedal but after holding the pedal down, it slowly starts to sink if the fluid is bypassing internally in the M/C.
HTH,
Robert
Old Mar 25, 2006 | 11:38 PM
vetred's Avatar
vetred
HTH,
Robert
and might as well replace the lines with braided steel and I also read something about dot 4 synthetic???
Old Apr 17, 2006 | 11:26 AM
JETSET's Avatar
JETSET
Default dot 4 synth
The manual says use only DOT3
the synthetic eats the seals supposedly in the pump
Old Apr 17, 2006 | 01:56 PM
yellow01's Avatar
yellow01
Back up a bit... What is happening? I can't quite understand.
You say it is bleeding fine, but you are saying once you tighten the bleed screw that the pedal still goes to the floor? Slowly or fairly quickly?
When you were bleeding did you ever run the resevoir too low (close to empty)?
Is the car running or off when this happens?
Are you sure you don't have any leaks? Clean all the connections up real good then put FRESH paper towels around the connections and push the pedal. Then check the fresh towels. Fluid that is leaking can run along the hose and end up in/on the frame/a-arm in many locations, so you may not immediately see drips etc.
More info will help with a diagnosis (i.e. a step by step with what you did, and what is happening at what step).
Old Apr 17, 2006 | 04:35 PM
JSTAN's Avatar
JSTAN
I am having this same problem. I just painted my calipers and reinstalled them. I bled all 4 brakes, but when I turn on the car and push down on the brakes, the pedal goes straight to the floor. There are no leaks anywhere. When I drive the car and slam the brake to the floor, the car doesnt come to a complete stop...its a slow gradual stop. I am completely stumped as to what the problem could be.
Old Apr 17, 2006 | 05:35 PM
Bill Dearborn's Avatar
Bill Dearborn
Need to know exactly what the symptoms are. For instance, if you are hitting the pedal once and it goes low and stopping power isn't sufficient you could have air in the lines. If you hit it a couple of times and the pedal level comes up and stays high and hard you more than likely have air in the lines. If you are pumping the pedal and then holding a hard/high pedal that gradually sinks you have a different set of problems.
Bill
Old Apr 17, 2006 | 06:58 PM
Snidley's Avatar
Snidley
One easy thing to check: did you put the calipers back on the same side of the car? With the bleeders at the top? I've heard of people putting them on the wrong side and the air trapped can't get out.
Old Apr 17, 2006 | 08:01 PM
JSTAN's Avatar
JSTAN
Yeah i just checked....they are on the wrong side, (bleeders on the bottom)....I will swap them over tomorrow, hopefully this will solve the problem.
Old Apr 17, 2006 | 08:06 PM
Snidley's Avatar
Snidley
Glad I could help. Always easiest to check the simple stuff first.
Old Apr 18, 2006 | 08:29 PM
JSTAN's Avatar
JSTAN
I flipped the calipers around and now the brakes work perfect.
Old Apr 19, 2006 | 04:11 AM
blktie8's Avatar
blktie8
I wonder if this holds true for front and rear .
All bleeder screws up.
Old Apr 19, 2006 | 04:14 AM
blktie8's Avatar
blktie8
So you had the calipers on the wrong side ,does this hold true for front and rear .
bleeder srews up
I thought one of the pairs were down
Either front or rear ,I'll have to check how mine are now
John
Old Apr 19, 2006 | 07:56 AM
JSTAN's Avatar
JSTAN
bleeder srews up
John
Yeah I had the front calipers on the wrong side, so the bleeder valve was pointing down. The rears were on correct and pointing up. Once I flipped the fronts around, having the valve point up, the car stops on a dime.
Old Apr 19, 2006 | 08:51 AM
Snidley's Avatar
Snidley
bleeder srews up
John
Bleeders have to be at the highest point on the caliper or air will be trapped.
To Brake Bleeding??
