Cartek clutch setup
Old Mar 27, 2006 | 03:07 PM
badbreg's Avatar
badbreg
Default Cartek clutch setup
Just seeing if anyone has tried carteks C5 clutch that comes with new adj. master and new slave for $944 posted on there website. Alot of people seem to like their adjustable master but havent heard much about the whole clutch setup. And yes this is because i have the sticky clutch FU***** issue on my 2000 with 12000 miles and am going to resolve it right the first time with aftermarket everything even though i just bought a brand new LS7 clutch setup im gonna stay away from GM OEM equipment
Thanks. Bob
Old Mar 27, 2006 | 08:29 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Thanks. Bob
I will be running it on my 750+ rwhp car within the next 2 weeks. I know of quite a few people that are running them with no problems. You should be fine
Old Mar 27, 2006 | 10:04 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I'm running it right now. Final dyno tune tomorrow but am already over 700 myself. Was going to the track yesterday but it is closed because if the Nationals next weekend so I can't comment on the track performance. Judging from its feel, it is going to be an awesome clutch. Grips like a mo fo and has a little chatter. I love it so far.
Old Mar 28, 2006 | 12:21 AM
stano's Avatar
stano
I like mine...5,000 plus miles and no problems!
Old Mar 28, 2006 | 10:17 AM
03 ZO6's Avatar
03 ZO6
I had one in the TA and I am putting one in the vette now. The clutch is great. I think it drives close to stock and grips like crazy when you need it. I did a ton of 6k+ clutch dumps on it at the track with ET Drags and it held great. The clutch always seemed like the hotter it got the harder it would grip.
Old Mar 28, 2006 | 12:17 PM
NONitro's Avatar
NONitro
Et drags !?!?!? Didn't know they made a 16 in the drag series
Old Mar 28, 2006 | 01:30 PM
03 ZO6's Avatar
03 ZO6
I ran those on the TA with 15" rims. I'll only be running 17" Z06 rims with DR's on the vette.
Old Mar 28, 2006 | 06:06 PM
jhong321's Avatar
jhong321
I am Happy with my Cartek so far 7000 mile and counting. I Had a spec 3+ and it was way to stiff and only lasted 5K miles
Old Mar 28, 2006 | 08:57 PM
badbreg's Avatar
badbreg
Sounds like the cartek is a great clutch. Did any of you have the sticky clutch before you went to it and know that this clutch setup is a for sure fix.
Old Mar 28, 2006 | 09:06 PM
see5's Avatar
see5
Went thru stock clutch then Z06 before the Cartek. No problem with Cartek but a little chatter when new.
I helped a friend put a LS7 in and that is a nice clutch as well. Lots of contact area and easy to drive.
Old Mar 28, 2006 | 10:43 PM
stano's Avatar
stano
At 62,000 on my '04 I never had the sticking clutch problems.
I do have the clutch spring removed and pedal feel is nicer...IMHO
To Cartek clutch setup
