Oil catch can possable solution
Old Mar 27, 2006 | 03:32 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Oil catch can possable solution
Well i think i found a solution for the catch can that might just work.
This is a industrial separator & filtration system.
It is primarily used to separate water from fuels. Also can be used to filter water and other contaminants from low pressure air lines.
They are not cheap around $80.00
I received good pricing for quantities of 10 or more.
The replacement filter is $30.00. I'm going to put it on my car tonight. See if it works. I found a PCV valve at auto-zone that screws right into the inlet.
Old Mar 27, 2006 | 03:36 PM
chriswtx's Avatar
chriswtx
Old Mar 27, 2006 | 04:02 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
It is about the size of a c5 oil filter.
You can paint the filter and polish the top might make it look kewl.
Certainly it has to work better than the ebay can.
Normal retail on the unit is $98.00 I'm working with the manufacturer on the filtration properties.
It can handle 80 psi of fluid pressure. So a few pounds of vacuum will not hurt it at all.
Old Mar 27, 2006 | 04:10 PM
killaz's Avatar
killaz
im in
Old Mar 27, 2006 | 04:25 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Originally Posted by killaz
im in
let me install first.
Trying to figure out how to actually test to see if it works.
I know it will catch oil just do not know how good of a job it will do.
So i'm the guinea pig again.
I have to change my setup because of ls1.
Would be good if someone else wants me to get them one for the z06 pcv system so more than one can test.
$80.00 plus shipping you would need to buy hose ends and pcv from autozone.
Old Mar 27, 2006 | 04:40 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
anyone have a writeup for the ls1 system.
Old Mar 27, 2006 | 04:43 PM
Dirty Howie's Avatar
Dirty Howie
Put a paper feul filter between the can and the intake. This will show you how much oil it is not catching. This is what I did.......
DH
Old Mar 27, 2006 | 04:57 PM
RED99's Avatar
RED99
I have been looking into this too. But I think it's going to take an oil / air seperator, and not a oil / water seperator. If that is what that is designed for. But what the heck, try it out and let us know. It may just be the ticket.
Old Mar 27, 2006 | 09:36 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
can someone post install instructions for the ls1 catch can set up.
Old Mar 27, 2006 | 10:28 PM
DBFCO2's Avatar
DBFCO2
Default I need them too
Old Mar 28, 2006 | 01:33 AM
Dirty Howie
Check this thread I started a couple of weeks ago:
http://forums.corvetteforum.com/show....php?t=1332352
Simply the hose from the valley cover goes into the can then out to the intake manifold.
DH
Old Mar 28, 2006 | 10:00 AM
Uncle John's Avatar
Uncle John
Try this link. Good pics.
http://www.cadillacfaq.com/faq/answe...tch/index.html
Old Mar 28, 2006 | 07:04 PM
LoneStarFRC's Avatar
LoneStarFRC
May be worth a shot. The only "variable" you may want to consider is the pcv valve itself. Depending on the designed flow/vacuum rating on the factory pcvs, any old replacement pcv valve may be significantly different and therefore skew your results. There is a relatively easy way around this though, and that would be to install the factory original pcv valve, using a brass fitting and some hose. That pcv valve you have screwed directly into the filter housing looks to have 1/4" NPT (maybe 1/8" NPT. Hard to tell size from photo). Using a brass fitting that has the same male thread on one end and a hose barb on the other end would work. Then it's just hoses and clamps, etc from there.
Food for thought.
Robert
Old Mar 28, 2006 | 07:21 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
I'm installing the ls6 valley cover tomorrow night.
I have to come up with a solution for one day for a Ls1 pcv system I removed today.
Old Mar 28, 2006 | 07:40 PM
vette113's Avatar
vette113
Default oil catch can possible
I have just installed a LS2 block in our 2003 coup. At a DE event two weeks ago, we blew out the oil dip stick and oil on the manifolds. I wanted to install a LS6 type valley cover. I do not know what Scoggin used when the build the system. However, you cannot use one of these in a LS2. Any have any ideas on what we need to do for DE days? Pewter and Yellow vette
To Oil catch can possable solution
