Ran my 1998 A4 with 2.73 gears at Moroso bone stock.....13.78 @ 102 with a 2.10 60' time (crappy gears/run craps). Added a K&N FIPK and hood seal as only mods....13.61 @ 103 with a better 2.02 60' time.
I hope so. My 2.73 LT1 '94 Formula went 13.61 stock and my '98 Formula with 2.73 went 13.25 with just a lid. I will be very bummed if my vette doesn't go at least 13.30s with the 2.73s. But here is an important question...what is your elevation? When I race I'm usually around 600 ft above sea level.
are you F*** serious man, i run at moroso. was there any track prep??? if not then something is wrong with ur car
Try running at the Las Vegas Motor Speedway in August. 115*, 10% humidity and 2,200 feet elevation. Density altitude about 6,800 feet. At these conditions, lots of stock C5’s run low 14’s and maybe just break into the 13’s. Takes a lot of the fun of drag racing away. I would love to run my car at sea level on a cool spring evening.
