Difference in MAF size, What years?
Old Mar 28, 2006 | 04:44 PM
gmblack3's Avatar
gmblack3
Default Difference in MAF size, What years?
In what year did the MAF change size and what is the size difference?
TIA!
Old Mar 28, 2006 | 04:48 PM
boosted_z06's Avatar
boosted_z06
TIA!
97-2000 75 mm
01-04 85 mm
Old Mar 28, 2006 | 06:44 PM
gmblack3's Avatar
gmblack3
Originally Posted by boosted_z06
97-2000 75 mm
01-04 85 mm
Thanks for the info!!!
Old Mar 28, 2006 | 07:34 PM
corvette Mark's Avatar
corvette Mark
What would happen if I put the larger 85mm maf into my 99 that currently has the 75mm maf? Would it be plug-n-play or would tuning be required? And if this were combined with the LS6 intake what gains could this yield on an otherwise stock engine?
Old Mar 28, 2006 | 09:45 PM
fdxpilot's Avatar
fdxpilot
01 and up MAFs have the IAT sensor built in and use a different plug. You would have to find an adapter harness, or do some cutting and splicing to make it work.
Old Mar 29, 2006 | 01:10 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Mark you can put on the larger screenless 02 and up Z 85mm MAF on your '99 but you would have to get a 2001 and up airbridge, wiring adapter harness since the plug is different on 2001 and up than your 99 and most importantly, you will need a tuning or any tuning software like EFI live, LS1 Edit etc to change your PCM's table over to the new MAF table.
I believe you can also buy a calibrated MAF along with the adapter wiring harness if you dont have the tuning software.
Here is a good read on the topic
http://www.ls1howto.com/index.php?article=25
HTHs
Old Mar 30, 2006 | 09:13 AM
corvette Mark
HTHs
Thanks for the link Nouman! good info!
I was thinking of buying the larger (85mm) maf ends to put on my factory maf but from what I read on this link it sounds like that would not match up with the maf tables in the pcm. I like the idea of the 02 screenless maf with larger airbridge. I could acquire the parts and keep them on standby until I do the Ls6 intake and headers and combine all the new parts together with a custom tune. Should I also be looking to upgrade the throttle body or are they all the same?
To Difference in MAF size, What years?
