My 99 LS1 has a vibration when the car is in gear. (AUTO trans) I traced it to the water pump pulley. Can it be changed without changing the pump? Cost? Degree of difficulty?
If you have 99 you should have a press fit pulley which to my knowledge and research is only replaceable when you purchase a new pump. If you get any other responces on how to remove and replace them please PM me.
get a 15mm deep wheel socket and a 3/8" ratchet turn the bolt that holds the plastic tensioner pulley clockwise this will release pressure on the belt.
remove belt from tensioner pulley
using same socket/ratchet combo find the 2 bolts that hold the tensioner body to the water pump housing turn these counter-clockwise and remove the tensioner assembly
