Corvette Questions
Old Mar 29, 2006 | 02:17 PM
John D's Avatar
John D
Default Corvette Questions
When I first start my car I hear a ticking sound or a slight knock some where around the top of the engine of my 2002 C5, 39,000 miles. When the car warms up it goes away. Someone said it may be an injector and that most C5 make some noise when they fist start up. Is this true?
Also have code H1214C traction control. Tried to reset but wont reset. Tried activating the abs by hitting the brakes but that didn't work. The abs is not working at all. Before I take the car to the dealer any help? I read up on a threads how to check for grounds, wires, sensors but can't seem to them .
John D
Old Mar 29, 2006 | 02:40 PM
dougbfresh's Avatar
dougbfresh
Piston slap maybe?
Old Mar 29, 2006 | 04:42 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
www.pistonslap.com
Old Mar 29, 2006 | 05:51 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Originally Posted by dougbfresh
Piston slap maybe?
That would be my guess. My 02 has it. Doesn't bother me.
Old Mar 29, 2006 | 06:53 PM
sorbet70's Avatar
sorbet70
my 02 with 7k makes the same noise until warmed up and from what i understand it is piston slap.i myself dont know what to do about it.there is so much info on this subject its hard to plan my next move.some say its normal, some say take it to the dealer before your GMPP expires.and the only way to fix it is to pull the motor and replace the rings and im not sure i want that done, how ever i dont want the motor to self distruct.i think as long as it stops once warmed up it should be ok. good luck
Old Mar 29, 2006 | 07:11 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
GM bought my truck back from me because of piston slap and excessive oil consumption. Are you consuming any oil? IMHO piston slap is very bad and causes wear on your engine. Good luck.
Old Mar 30, 2006 | 12:52 PM
John D's Avatar
John D
Default C5 questions
I'll check the oil level tonight see if any changes..
Old Mar 30, 2006 | 04:33 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Piston slap maybe?
That would be my guess too.
Old Mar 30, 2006 | 04:43 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by screw991le
That is THE BIGGEST site that I have ever seen. The designers, followers and believers of that crap should be shot in the face. It is amazing what idiotic, misinformed douchebags can come up with when they have too much GM hating free time on their hands.
Old Mar 30, 2006 | 07:02 PM
sorbet70's Avatar
sorbet70
im starting to think the samething.....im going to just give her a nice shot of techron this weekend and see what happens
Old Mar 30, 2006 | 08:16 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
John D
I think your code problem is much more serious then the piston slap. If you take it to the dealer, they will just start replacing everything until it goes away. All on your dime might I say. I would check for grounding problems and bad connections first. Look at the electrical post by Bill Curlee in the tech section for an idea of how to begin.
Good luck,
Clayton from Las Vegas
To Corvette Questions
