Radiator top shroud. Needed?
Old Mar 29, 2006 | 07:27 PM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
Default Radiator top shroud. Needed?
Can I take it off or is it needed for flow through the rad?
Old Mar 29, 2006 | 07:35 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default I think you need it!
If I remember correctly, the radiator can move up without the top cover.
Bob K.
Old Mar 29, 2006 | 07:43 PM
Warp Factor's Avatar
Warp Factor
Without it, air dumps to the engine compartment over the top of the radiator instead of going though the radiator.
Old Mar 29, 2006 | 07:46 PM
burbleflyer
St. Jude Donor '08
Bob K.
Good to know. I can fab a bracket to hold it down.
What I'm trying to do is build a custom intake and I need clearance for the tube. I may just cut the shroud and fit some Kydex but if I can lose the shroud it'll be easier.
Old Mar 29, 2006 | 07:47 PM
burbleflyer
St. Jude Donor '08
Like all the other cars I've owned that have no shroud?
Will it cause cooling issues?
To Radiator top shroud. Needed?
