Power window problem
My passenger window quit working today. Both the passenger side and driver's side window switches won't activate the window. Good thing its stuck in the "UP" position!
I searched the Tech threads and found several similar problems. I've tried the "door slamming while holding the switch down" and "wiggle the accordian in door hinge area" methods to no avail.
I also pulled and checked the Right Door Control Module and Power Feed Door Right fuses and they both looked good.
Am I missing any simple fixes? I would appreciate any advice before I throw in the towel and take it to the dealership to invoke my warranty!
Sully
Sully
i had a problem with my drivers side window about three weeks ago would not go up or down we took off the door panel today and tapped my regulator with a hammer a couple of times and it started to working a friend has done thin os twenty vettes and told us to try so we did and it worked whew hope it keeps working.
