Wierd Starting Problem
I just installed my new stereo and my car is doing something it usually doesn't. There is a delayed starting when i turn the key (i.e. i turn the key to start it, and it doens't crank for about 3 seconds) I am pulling about 13volts so my battery is fine. I'm thinking it could be the power lead that I tapped into to power my radio. I was told on the forum that it was fine to tap into. It was a yellow wire running just over the fuse box in the footwell. I'm not sure what it was (neither did he) but the radio works fine!
Any help would be appreciated!
Thanks,
Josh
