Removed Air System...issues?
Old Mar 31, 2006 | 10:01 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Removed Air System...issues?
I am pretty sure that my air system has been tuned out, but if it hasn't, what issues will I see removing the entire system? I put block off plates on my headers to prevent issues there. Just curious.
Thanks,
Micah
Old Mar 31, 2006 | 10:18 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
did you block off the vacuum hose to the air pump if '01 or newer? if not tuned out, you'll get codes
Old Mar 31, 2006 | 10:36 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i'm new to this area...what is the purpose of not using the air tube?
what does it do and why would you not want to use it?
thanks.
Old Apr 1, 2006 | 06:24 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
thanks.
The air system is only at work the fist thirty seconds of the car initially being on and seriously it just looks to busy with all that tubing in, so I bought block off plates and removed the stuff that is behind the manifold and decided to disconnect and remove the pump and everything else.
Old Apr 1, 2006 | 10:58 AM
jdmvette's Avatar
jdmvette
Night Owl for life
are they an emissions thing?
Old Apr 1, 2006 | 12:51 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I think so.
Old Apr 1, 2006 | 01:29 PM
bomax's Avatar
bomax
It helps heat up the cats more quickly. It's strictly for emissions. No harm in removing the system, as long as you program out the code it will throw.
Old Apr 1, 2006 | 03:21 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
It injects O2 into manifolds before cats heat up. I removed mine and no problems except an extra box of parts
Old Apr 1, 2006 | 09:08 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Things are removed and running fine with no codes!
Old Apr 2, 2006 | 01:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
where'd you get the block off plates?
Old Apr 2, 2006 | 07:05 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
thunderracing.com (call them) and tell them you need the air system block off plates, they were 9.95 each and you need two.
To Removed Air System...issues?
