Front Turn Signal Bulb
Old Apr 1, 2006 | 11:12 AM
C5 Fly By's Avatar
C5 Fly By
5th Gear
Default Front Turn Signal Bulb
This may be a simple question. Does anyone know how to get access to the left front turn signal bulb on a C5?
Thanks!
Old Apr 1, 2006 | 12:12 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
couple way...pull down the brake duct and reach in...or i pull the black headlight bezel and reach down...
Old Apr 1, 2006 | 01:40 PM
Oldvetter's Avatar
Oldvetter
The shop manual calls for: jacking up that side of car, removing panel on bottom of car (about 4 or 5 screws), move brake cooling duct, reach up and twist out bulb holder, replace bulb. There is limited space, I find I have to use one hand to replace bulb.
Old Apr 1, 2006 | 02:08 PM
C5 Fly By's Avatar
C5 Fly By
5th Gear
Default Thanks
Thanks for the replies. I removed the bezel and did it from the top. FYI, the new Sylvania LL bulbs are a pain to fit in the socket. They need a little WD-40 to slide in and the fit is tight.
To Front Turn Signal Bulb
