People with Kooks headers step inside
Old Apr 1, 2006 | 02:14 PM
scaperman's Avatar
scaperman
Default People with Kooks headers step inside
I'm installing the kooks headers myself which i have everything off and started installing the kooks in, but the instructions say cut the pipes before the cats and weld flanges on,i thought these would have bolted to the old flanges?Did i purchase the wrong ones my car is a 98 i bought the 1 3/4 ones with air tubes please help
Old Apr 1, 2006 | 06:01 PM
KOOKS Headers's Avatar
KOOKS Headers
Default kooks
Did you buy our x pipe as well? If yes it is a direct bolt on application
Old Apr 1, 2006 | 06:09 PM
LoneStarFRC's Avatar
LoneStarFRC
True story. (And he ought to know) . I have the 1 3/4" with Kooks X-pipe. Plug-N-Play as they say. The only PITA part was the jacking the engine over on the install. Been solid ever since.
BTW, I like the factory steel gaskets.
Old Apr 1, 2006 | 06:26 PM
scaperman's Avatar
scaperman
Thanks for the info,by putting on the x pipe is that eliminating my cats?I already have corsa tigershark with corsa x pipe.
Old Apr 1, 2006 | 06:31 PM
LoneStarFRC
No. There are two different versions and the one I (and most people I suspect) go with, are the street versions, that come with high flow cats. Emissions legal and still a bolt on deal.
BTW, I removed my Corsa X-pipe and factory exhaust manifolds when I did my install. Still have the Corsa cat-back system (Touring w/Pro tips)in place though. HTH
Old Apr 1, 2006 | 06:46 PM
scaperman's Avatar
scaperman
Lonestar thanks for the info there is two kinds of x pipe one that is oem converters back or hp metallic converter which one should i get?
Old Apr 1, 2006 | 10:25 PM
LoneStarFRC
I haven't checked the Kooks info lately, but last time I did, in order for you to keep your factory cats, you would have to do some cutting and welding, etc. The easiest way to go would be to just use the complete Kooks mid-section (their high flow cats plus x-pipe). Everything just bolts right up using clamps, etc.
Remember: the Kooks collector ends have what I like to call a "ball and socket" type joint instead of the old fashioned flat flanges (can you say prone to leakage?) and the pipe section immediately behind these header collector connections (mid-section pipe assy) obviously has to have the same design in order to mate up. BTW, they are not the only folks out there using this design collector connection as it has proven very reliable, leak resistant and become popular.
Remove the Corsa X-pipe, keep the clamps, etc and sell it. It is a good rugged x-pipe and you should not have too much trouble selling it as some folks just want the kind of set-up you had, before going with the Kooks headers, etc.
Bottom line? Kooks from engine to over axle pipes (including their high flow cats).
Old Apr 2, 2006 | 04:17 PM
KOOKS Headers
We also offer a stock cat hook up you can call me tool free at 1 866 586 kook on monday and I will guide you in the best direction for your app. George R
To People with Kooks headers step inside
