Help Codes!
Old Apr 1, 2006 | 05:29 PM
happa's Avatar
happa
Default Help Codes!
Ok I had a code last week and found it and fixed it. Now it came back, with another code. The code I replaced was P1133 and it came back. The other one is P1153. That is Heated Oxygen Sensor Bank 2 Sensor 1-B. Where is that at? And did I replace the right one on the P1133 code. Its the Heated Oxygen Sensor Bank 1 sensor 1-8. It was on the Driver side exhaust manifold. Thanks for the help!!!!
Old Apr 3, 2006 | 04:24 PM
happa's Avatar
happa
Anyone?
Old Apr 3, 2006 | 09:30 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
P1153 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
Bank 2 = passenger side; sensor 1 = front (before cat).
HTH!
Old Apr 3, 2006 | 11:44 PM
happa's Avatar
happa
Man thank you so much. Do you think the other side I replaced was a bad sensor? Thank You again!
Old Apr 4, 2006 | 12:18 AM
killaz's Avatar
killaz
i had the same problem. My air tubes were leaking and causing those codes. Replaces my airtube gaskets and poof, codes went away.
Old Apr 4, 2006 | 01:07 AM
Wisdom's Avatar
Wisdom
Where are the air tubes?
Old Apr 4, 2006 | 02:23 AM
killaz's Avatar
killaz
look on your exhaust manifolds (headers if you have them) they are the tubes that hook up there.
To Help Codes!
