Quick Tip needed Bleeding C 5 brakes
Old Apr 1, 2006 | 06:03 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Quick Tip needed Bleeding C 5 brakes
Any special tricks?
Jack
Old Apr 1, 2006 | 06:33 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
I'm serious
seeya
Old Apr 1, 2006 | 08:07 PM
IM QUIKR's Avatar
IM QUIKR
speed bleeders.
Once you install them, one at a time you crack them lose by 1/4 turn and pump the pedal. start from the furthest and work your way to the master. RR, LR, RF, LF. I like to start the first wheel and pump it down until the res is almost empty and then top off with new fluid and flush all 4 lines until all fluid exiting is clean. Some folks like to alternate ATE super Blue and gold so they know when the new fluid is at the wheel. Plan on a quart of fluid and if you are limber you can do it without lifting the car. I've done it so many times now I just reach around the wheel. Only can be done with "speed bleeders." they are worth every penny. $15 for a set.
NOTE: don't let the resevoir go dry. Once air is in the system you need a Tech II to pump the ABS. Just don't do it. After driving, double check to see there's no fluid leaking on the rims. There's really nothing to it.
Good luck.
IQ
PS fill in your profile! Some procedures are different for certain model years. You never know when you've been given bad advice.
Old Apr 1, 2006 | 10:40 PM
Dirty Howie's Avatar
Dirty Howie
The correct order for I think 2001 and up (I know its right for 2004) is:
RR, LF, LR, LF
And I like my Speed Bleeders too
DH
Old Apr 1, 2006 | 11:07 PM
IM QUIKR's Avatar
IM QUIKR
Originally Posted by Dirty Howie
RR, LF, LR, LF
DH
Old Apr 2, 2006 | 01:23 AM
Dirty Howie
Originally Posted by IM QUIKR
IM QUIKR........
IM SMARTER.......
Do a search and show me I'm wrong. I havn't been wrong in more than 24 hours now
DH
Old Apr 2, 2006 | 04:37 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
speed bleeders.
Good luck.
IQ
Old Apr 2, 2006 | 11:16 AM
IM QUIKR's Avatar
IM QUIKR
IM QUIKR........
IM SMARTER.......
DH
Howie Howie Howie...
How many times must this fellow bleed the LF wheel?
RR, LF, LR, LF
Sorry to bust your bubble but now you must start the clock over on your sparkling record.
"Smarter" is subjective now, isn't it?
Old Apr 2, 2006 | 12:51 PM
bomax's Avatar
bomax
In all seriousness, I also have heard you start farthest from the master and work your way in.
Old Apr 2, 2006 | 02:07 PM
SpeedyZ's Avatar
SpeedyZ
RR, LF, LR, LF
Q: Howie many times does it take Howie to bleed C5 brakes with air in the RF?
A: A LOT
Just giving you a hard time Howie, we know you meant RR LF LR and the other LF!
2001 manual says RR LF LR RF for both manual and pressure bleeding.
Old Apr 2, 2006 | 02:18 PM
Oldvetter's Avatar
Oldvetter
If you are bleeding brakes by pumping the pedal, throw a 2X4 piece of wood under the brake pedal. This keeps the master cylinder piston from travelling too far and possibly scraping o-rings on "build up/wear" area.
Correct squence is:
1997-2000 RR, LR, RF, LF
2001-2004 RR, LF, LR, RF
Old Apr 2, 2006 | 07:39 PM
Dirty Howie
Yes I meant .... the last one is RF
GODDAMNED old age.........
PS: IMSTILL SMARTER but being IMQUICKER is better
DH
Old Apr 3, 2006 | 12:05 AM
Ducati749's Avatar
Ducati749
CRAP i went out of sequence.....what now, rebleed correctly?........
Old Apr 3, 2006 | 12:42 AM
Dirty Howie
Did you do the left front twice?????
DH
Old Apr 6, 2006 | 02:28 AM
Ducati749's Avatar
Ducati749
hahaha no, but i honestly cant remember which order i did it in...
Old Apr 6, 2006 | 06:54 AM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
I also just did my '04 out of order (RR, LR, RF, LF) last weekend. No apparent "bad" effects.
I used ATE Super Blue brake fluid, so I had a clear visual indication that I had clean fluid at each wheel. All seems to be good, so I ain't going' back in there
Old Apr 6, 2006 | 10:38 PM
Ducati749's Avatar
Ducati749
sounds good ill let it be...but if I crash im comming after you
jk
To Quick Tip needed Bleeding C 5 brakes
Old Apr 7, 2006 | 12:42 PM
2KVetteMan's Avatar
2KVetteMan
Where do you buy your speed bleeders?? At any auto shop?
Thanks.
Old Apr 7, 2006 | 12:58 PM
mneblett's Avatar
mneblett
jk
You'll have to catch me -- if you're not stopping, I probably won't be able to, either!
Old Apr 7, 2006 | 08:59 PM
pewter99's Avatar
pewter99
Thanks.
Vette Brakes and Products have them http://www.vbandp.com/
