Vacuum pumps: pics
Apr 2, 2006 | 03:44 PM
Vacuum pumps: pics
Apr 2, 2006 | 07:13 PM
Very nice. I wish I could use that one but there's no spce available. Just a side note, your plug wire #2 is burning.
Apr 2, 2006 | 08:15 PM
4th Gear
if thats the A&A pump, i take it you will stop flaming A&A now ,right?
Apr 2, 2006 | 09:10 PM
Quote:
WTF are you talking about?
Apr 2, 2006 | 10:19 PM
Apr 2, 2006 | 11:26 PM
Here is one of the catch cans I made. We used 6061 3" aluminum tubing, 4" tall with -12 fittings on the top. We still need to drill/tap the mounting bosses and add the petcock. Has about 10 minutes of polishing done and about 20 minutes left.
Apr 2, 2006 | 11:37 PM
Quote:
Check that wire Phil...it looks about done from the picture!
Apr 3, 2006 | 10:36 AM
Phil,
Looking pretty sweet!
Thanks again,
Charlie
Apr 3, 2006 | 10:46 AM
Educate me please, what would you use a vacum pump for?
thanks.
Apr 3, 2006 | 01:23 PM
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Quote:
thanks.
Basicly creating a vacuum in the crank case helps seal piston rings better. Looks good Phil
Apr 3, 2006 | 01:32 PM
Thanks guys, tonight I am going to finish polishing the the catch can and start on the other 6. Hopefully the valve covers will be here soon.
Phil
Apr 3, 2006 | 09:40 PM
St. Jude Donor '06
Phil,
I just upgraded to that pump a week or so ago. It looks and works great!
BTW, if you ever have a need to replace the belt (or just want a stronger one), McMaster-Carr carries them. Just search their online catalog for 56-tooth Kevlar timing belts. Unlike the Gates belts, it is a full ½" diameter, so it will fill those pullies...with no slop.
Apr 3, 2006 | 10:06 PM
Great looking setup you have their
Apr 3, 2006 | 11:17 PM
Spent another 10 minutes polishing... getting closer
Apr 3, 2006 | 11:42 PM
Phil; your work (as usual) is top-notch
Apr 4, 2006 | 12:22 AM
Cruise-In VII Veteran
pump looks mint!! looks like a unit you see in the aerospace biz
Apr 4, 2006 | 08:39 AM
Quote:
Dude...Turning out great. Hook me up!!!
Apr 4, 2006 | 10:38 AM
Kevin,
Do you want me to make one for you?
Phil
Apr 4, 2006 | 12:48 PM
Kevin,
Phil
Phil,
Why not? You don't have all my money - yet!
Will this work on an LS2 402 next winter?
