octane level
Old Apr 2, 2006 | 08:16 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Default octane level
this is off topic but if I put a superchargeron my '01 Silverado, will I have to bump up the gas from regular to premium? Not an issue the the vette as it is already on premium.
Old Apr 3, 2006 | 04:23 PM
Drako's Avatar
Drako
Yes you should run the highest pump gas octane available. Also try to find someone to tune the PCM to run a ~11.5 Air Fuel ratio, and pull about 1* of timing per pound of boost. I'd also recommend running a slightly colder set of spark plugs.
You might find that your stock fuel system is no longer able to keep up with the supercharger (injectors running at 100% duty cycle, or fuel pressure dropping at higher RPM) - keep an eye on this.
If tuned properly all of this should keep your stock motor 'relatively' safe at or below 8lbs of boost.
