Lowering radiator?
Old Apr 3, 2006 | 09:11 AM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
Default Lowering radiator?
I want/need to lower my radiator an inch or two. Is there a kit available or a "how to" article anywhere?
Anyone ever done this?
Old Apr 3, 2006 | 11:45 AM
corvettebob1's Avatar
corvettebob1
Call Andy at A&A Corvette 805-278-4107 he will treat you right!
Old Apr 3, 2006 | 03:14 PM
Mike04's Avatar
Mike04
A&A's supercharger kit lowers the radiator by cutting the lower support and re-attaching the support forward of the original position. Works great. Give them a call.
Old Apr 3, 2006 | 03:26 PM
Sportsdude's Avatar
Sportsdude
ECS has a kit also.
Old Apr 3, 2006 | 11:57 PM
burbleflyer
St. Jude Donor '08
I've got a killer intake fabbed up and I need the rad out of the way.
This rad lowering, it involves cutting and welding?
Old Apr 4, 2006 | 12:05 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yes/no, cut the crossbar and move forward w/ the brackets that are bolted in; welded is better and looks
Andy has a 'how to' on the website
you'll also need to cut the lower hose and install an extension, the upper hose will most likely need the same treatment to get around the ebcm
Old Apr 4, 2006 | 12:36 AM
burbleflyer
St. Jude Donor '08
That's what I'm looking for but I can not find it on his website. Got a link?
Old Apr 4, 2006 | 12:03 PM
SteveDoten's Avatar
SteveDoten
https://www.aandacorvette.com/supercharger_inst.asp
Old Apr 4, 2006 | 05:45 PM
burbleflyer
St. Jude Donor '08
You are da man! Thanks very much!
To Lowering radiator?
