AUTO TRANNIES
Old Aug 17, 2001 | 01:22 PM
ROD BROWN's Avatar
ROD BROWN
Default AUTO TRANNIES
i read somewhere(don't remember where), driving a vette with an automatic trannie aggressively will make the computer adjust the shifting more positive.is this a fact or is the author of this article blowing smoke up my you know where?
:chevy
Old Aug 17, 2001 | 01:33 PM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: AUTO TRANNIES (ROD BROWN)
Hi there,
Well, it really depends on what you are refering to.
First, the tranmission adaptive settings is the computers ability to compensate shift points for internal wear of the clutches, bands, and other components.
Second, under full throttle acceleration, your PCM will increase line pressure to increase the speed in which apply components work during a shift. The PCM sees the time that the shift takes, and will compensate to a slight degree, however, it will NOT understand and therefore increase shift points, just for a driving style.
It will only see shift times, and with the trans adaptive settings, compensate accordingly.
Best to all, c4c5
