I really don't know anything when it comes to this. I did a search and read many threads but am still unclear about the following question: Is the actuator the same thing as a slave cylinder? If it is, I assume it comes with the throw out bearing, or is that also the same thing. I have a 02 Z06 and am putting in a SPEC Stage 2 clutch/flywheel. Is there an upgraded slave/actuator/bearing I should consider or just go with the stock part from GM. Any advice is GREATLY appreciated!
