Checking resistance on 99 C5 key?
Old Apr 5, 2006 | 01:49 PM
99 C5 ragtop's Avatar
99 C5 ragtop
Default Checking resistance on 99 C5 key?
Can I determine with a volt meter at home the resistance of my one and only '99 vette key so I can order the correct replacement? I was quoted $60 for a new key awhile back at a Chevy dealer and they had to order it..
Old Apr 5, 2006 | 02:14 PM
dougbfresh's Avatar
dougbfresh
Yes, a VOM will work fine. Just make sure to zero it before you test and be on the 1 ohm scale, the last one I measured was 14 ohms.
Old Apr 5, 2006 | 02:35 PM
rws.1's Avatar
rws.1
To find your Vats# measure the resistance between the two poles of the resistor ( VATS pellet)that sticks out in the key. Use this chart to calculate your # The Vats number is the one that is closest to the resistance you measure
The 15 resistor codes are:
Key# Value (Ohms)
1 392
2 523
3 681
4 887
5 1130
6 1470
7 1870
8 2370
9 3010
10 3740
11 4750
12 6040
13 7500
14 9530
15 11800
I bought my blanks on eBay from the vendor called locksmithsource.
Two blanks delivered cost me under $15. A local locksmith that specializes in VATS keys cut them for $2 each. Total cost for 2 keys under $19 !
To Checking resistance on 99 C5 key?
