Air pump ??
Old Apr 5, 2006 | 10:50 PM
4deatr's Avatar
4deatr
Default Air pump ??
What does it do?
Why is mine so bad and this is my second one.
Old Apr 5, 2006 | 11:11 PM
SpeedyZ's Avatar
SpeedyZ
If your talking about the AIR (Air Injection Reaction) pump down under the left headlight it is used when the engine is started cold to help fire off the cats quickly. When the engine is started cold it will run richer than normal dumping more unburned fuel into the exhaust, the AIR pump blows fresh air into the exhaust which will help burn the extra fuel in the cats. This heats the cats up fast therefore less emissions. After the cats are up to temp there is not need for the pump anymore and it is shut off. If you don't have cats there is no reason to have the AIR pump other than to pass inspection.
Old Apr 5, 2006 | 11:20 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
there's a solenoid high on the pass. fender support, that may have failed or one the ck valves is bad, this will allow the pump to run constantly, what codes do you have? 1415,1416 are the ck valves
Old Apr 5, 2006 | 11:38 PM
dragon84's Avatar
dragon84
it pumps up the tard driving the yellow vette haha SYKE. Marty how have yo been buddy?
Old Apr 6, 2006 | 08:07 AM
4deatr's Avatar
4deatr
I don't have any codes it is just loud. I just had a new one put in and that one is loud. So can I turn it off?
Old Apr 6, 2006 | 08:09 AM
4deatr's Avatar
4deatr
Hey Tom I'm great how are you. You should come up sometime soon. Im me your number.
Old Apr 6, 2006 | 09:11 PM
4deatr's Avatar
4deatr
ttt
Old Apr 16, 2006 | 04:17 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Its a fast running pump, and unless you can put some sound dampening around it , its going to be loud. But, yes you can turn it off electronically.
Your tuner can.
To Air pump ??
