Squeaky rear end
Old Aug 17, 2001 | 10:36 PM
Big T's Avatar
Big T
Default Squeaky rear end
Hello all,
I need help diagnosing and fixing a squeaking rear end on my 98 Coupe. It is a high pitched squeal which I only hear when I am going slow - say 5 mph or less. It is also definitely periodic with the rotation of the rear end - when I go faster the frequency of the squeak increases.
My personal theory is that it has something to do with the parking brake. It tends to happen more when I've used the parking break on a downward-facing slope, and sometimes I can make it go away by coming to a stop and yanking up and down on the parking break handle a few times.
Any help is much appreciated!
Old Aug 18, 2001 | 01:14 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Squeaky rear end (Big T)
I have seen where the retaining spring that holds the parking brake shoe to the backing plate pop off or break.When this happens,the spring will drag inside the rotor,possibly causing a squeek...
Old Aug 20, 2001 | 10:47 PM
Big T's Avatar
Big T
Default Re: Squeaky rear end (C-5 TECH)
Is this something I can diagnose/fix myself, or is it time to visit the dealer?
Old Aug 20, 2001 | 10:55 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Simply unbolt the rear caliper and slide the rotor off to inspect the parking brake shoes and hardware...
To Squeaky rear end
