Help needed! Check engine light greeted me today.
Old Aug 17, 2001 | 11:33 PM
sandyg's Avatar
sandyg
Default Help needed! Check engine light greeted me today.
I was greeted today by the check engine light. I checked the codes and the one that stood out was PO803 H C. This is the diagnostic for the Skip Shift Solenoid Circuit. I cleared the code and the check engine light went off. I have had a CAGS in for almost 2 years without a problem.Has anyone experienced this. Is it likely that the CAGS unit has gone bad? I have tried repeatedly to reset the computer and remove the code but as soon as I activate the 1to4 light I generate a code. I do not get the check engine light anymore. Advice will be appreciated. Thanks.The only recent work on my car was the recall work done by the dealer on the column lock. :confused:
Old Aug 18, 2001 | 12:06 AM
MDT's Avatar
MDT
Default Re: Help needed! Check engine light greeted me today. (sandyg)
sandyg,
Why not cycle the connector back there at the CAGS mod? Might be that a poor contact is giving an "open" and causing the code to set.
Hope that works.
Good luck.
Mark
Old Aug 18, 2001 | 05:25 PM
sandyg's Avatar
sandyg
Default Re: Help needed! Check engine light greeted me today. (MDT)
Thanks for the reply. What do you mean by "cycle " the cags ?
Old Aug 18, 2001 | 11:17 PM
blackjack's Avatar
blackjack
Disconnect the CAGS connection and reconnect. It will hopefully clean the terminals and improve the
situation.
Old Aug 19, 2001 | 02:30 AM
MDT's Avatar
MDT
sandyg,
Yeah, "cycling the connector" means what blackjack said.
Mark
To Help needed! Check engine light greeted me today.
