Alignment settings for lowered car
Old Apr 6, 2006 | 09:09 PM
JasonS's Avatar
JasonS
Default Alignment settings for lowered car
Hello,
I'm considering buying a set of Z07 rims (18x11 and 18x9.5) for my C5 coupe, and would like to lower the car maybe 3/4" or so, but not more. I've read that lowering the car will cause excess wear on the inner treads unless you re-align to the stock camber settings. My question is, going with the wider tires, should I set this to the Z06 settings or just the stock C5? Will it make much of a difference which? I plan on keeping the stock C5 suspension components, at least for now.
Any thoughts would be greatly appreciated.
Cheers
Jason
Old Apr 7, 2006 | 06:13 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Based on what many have said in the past, if you're going to use run-flat tires, stay close to the OE coupe and convertible alignment specs. If you're going to run non-RFs, go with the Z-06 specs.
Old Apr 7, 2006 | 08:26 AM
WKMCD's Avatar
WKMCD
I'm all the way down on stock bolts with 18's all around. I run the Z06 specs but with only 5 degrees of camber on the front. It's a little easier on the insides of the front tires.
Old Apr 7, 2006 | 09:20 AM
yellow01's Avatar
yellow01
I'm with leadfoot. Runflats are very stiff and don't like much camber. You'll get excessive wear inside.
Non-runflats are much more forgiving.
Camber isn't nearly as hard on tires as toe. If you are running non-runflats and stock toe settings, going to Z06 camber settings should be fine and will give you just a bit more contact patch in corners (if this is of concern).
I'm running -1.5F, -1.0R with a fair amount of toe (out F, in R, I forget how much) and I don't see wear being too bad. There's some, but I track, and the handling is worth the street wear to me. Depending on the tires you run, you could always slide them to the other side after some number of miles.
I think you meant caster (I'm guessing a typo) and WOW that's pretty low... What's your high speed stability like?
Old Apr 7, 2006 | 09:29 AM
leadfoot4's Avatar
leadfoot4
For what it's worth, 5 degress of CAMBER would have you driving on the sidewalls! And yes, IIRC the factory settings call for 6.5-7 degrees of caster.
Old Apr 7, 2006 | 10:30 AM
ZBrink's Avatar
ZBrink
St. Jude Donor '06
I just lowered my 98' all the way on the stock bolts and I run factory sized wheel/tires using non-runflats. My car is pretty stock and it is mostly driven on the street. Can somebody give me full alignment specs that I should go with? This way I can write them down and take them to the alignment shop. Spell it all out please because I know nothing about alignment.
Thanks!
Zack
Old Apr 7, 2006 | 11:40 AM
WKMCD's Avatar
WKMCD
OOPS! I did mean caster. Not paying attention.
Old Apr 9, 2006 | 07:51 PM
JasonS's Avatar
JasonS
Zbrink, I found the following alignment data from the forum, I hope this helps....the first set of data appears to be for a stock C5, and the second set is for the various suspension options (including Z06 specs)...hopefully someone can validate this.
Cheers
Jason
Stock C5:
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe: +0.08 degree +/- 0.20 degree
Front Individual Caster: +7.4 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.50 degree
Front Individual Camber: -0.20 degree +/-0.50 degree
Front Cross Camber: within +/-0.50 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.18 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
Wheel Alignment Specifications
RPO
Operation
Service Preferred
Tolerance
Front Alignment Specifications
All
+ 0.04
+/- 0.10
All
Front Sum Toe
+ 0.08
+/- 0.20
All
Steering Wheel Angle
0.0
+/- 1.0
FE1 & FE3
+ 7.4
+/- 0.5
FE1 & FE3
Front Cross Caster
Within +/- 0.5
FE1 & FE3
- 0.20
+/- 0.5
FE1 & FE3
Front Cross Camber
Within +/-0.5
FE4 (Z06)
+ 6.9
+/- 0.5
FE4 (Z06)
Front Cross Caster
Within +/- 0.5
FE4 (Z06)
- 0.70
+/- 0.5
FE4 (Z06)
Front Cross Camber
Within +/- 0.5
Rear Alignment Specifications
All
Rear Individual Toe
- 0.01
+/- 0.10
All
Rear Sum Toe
- 0.02
+/- 0.20
All
Rear Thrust Angle
0.0
+/- 0.10
FE1 & FE3
- 0.18
+/- 0.5
FE1 & FE3
Rear Cross Camber
Within +/- 0.5
FE4 (Z06)
- 0.68
+/- 0.5
FE4 (Z06)
Rear Cross Camber
Within +/- 0.5
To Alignment settings for lowered car
