P1431 Fuel Level Sensor 2 Circuit Performance -C, What do I do now?
Old Aug 18, 2001 | 02:27 AM
C5Noir's Avatar
C5Noir
Default P1431 Fuel Level Sensor 2 Circuit Performance -C, What do I do now?
I'm glad my car is under warranty. I was crusing at 60 MPH on the highway and my fuel gauge dropped to zero and the Check Gauge light illuminated. The code is P1431. Do they just replace the fuel sending unit? Thanks for all your help. :D
Old Aug 18, 2001 | 07:01 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: P1431 Fuel Level Sensor 2 Circuit Performance -C, What do I do now? (C5Noir)
Hi there,
There is a bulletin for this concern, and it is published in SI2000, you should have no problem in repairing this issue. You right side fuel tank sending unit will have to be diagnosed, and if bad, replaced.
Best to you, c4c5
Old Aug 18, 2001 | 01:19 PM
John Nowak PE's Avatar
John Nowak PE
Had the same thing happend to my 01 Coupe. The dealer is going to fix things on Tuesday. My dealer is going to replace both sending units and the module. I'll post my results next week. BTW, when you take yours in for repairs, make sure the tank is as empty as possible.
[Modified by John Nowak PE, 11:20 AM 8/18/2001]
Old Aug 22, 2001 | 11:32 PM
John Nowak PE
So far so good...problem seems to be fixed. I am travelling to West Yellowstone this weekend for the "Wild West Vette Fest"; we'll see if it truly is fixed.
BTW here is what my dealer replaced
1 88895126 W-Module Kit
1 88899034 Sensor Kit
1 12459862 Strainer Kit
[Modified by John Nowak PE, 9:32 PM 8/22/2001]
To P1431 Fuel Level Sensor 2 Circuit Performance -C, What do I do now?
