98 vette headlite ajustment
Old Apr 7, 2006 | 09:56 AM
jjsgroi's Avatar
jjsgroi
Default 98 vette headlite ajustment
was wondering if anyone knows how to adjust low beam headlites to be higherpoped off cap on side found a adjusting screw but not sure if thats the correct one to raise lites a bit thanks for any help
Old Apr 7, 2006 | 11:13 AM
NJ Vette Guy's Avatar
NJ Vette Guy
That's the one......
It's a #15 torx on a long stem. I found that it wobbled too much and used a 1/4 socket instead. You will have to turn it a bit to see the light move.... I did it with the light shining on my garage door and "ball parked" them in, to get the same height, but then I drove the car to actually fine tune the adjustment. I also replaced and adjusted the fog lights to help "flood" in the low beam's lights, I used 50W 885's.
I suggest that if you want better light, you should invest in Sylvania "Silver Star" lights..... 9005 and 9006..... I did and they work great.
Old Apr 7, 2006 | 12:46 PM
jjsgroi's Avatar
jjsgroi
thanks for the reply will do the adjust first and maybe new bulbs
To 98 vette headlite ajustment
