Installing SS or chrome pad plates.
Old Apr 7, 2006 | 04:02 PM
Baron138's Avatar
Baron138
Default Installing SS or chrome pad plates.
A question for those with stainless or chrome brake pad plates. When puting them on, is there any prep work with installing them or do you just put them on between the pads and the caliper? I thought there were some "dimples" on the pads that might be in the way. Any help would be appreciated before I buy them.
Old Apr 7, 2006 | 04:10 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yeah, the pads have a few "nubs" on the backside that stick out a little. Not sure why they are there, probably just a byproduct of the manufacturing process. but they are by no means necessary for proper brake function. (no harm in removing them).
I just ground them off on a bench grinder. Could be done with a hand grinder or even a dremel...not a big deal if you got the tools.
Other than that, just slip 'em in and enjoy!
Old Apr 7, 2006 | 05:16 PM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
If you need to, make sure you bleed the brakes before installing the pad covers
To Installing SS or chrome pad plates.
